Any need or reason to do this on a 200cid with adjustable rockers?
Or is the initial shop manual set up procedure enough?
Shop Manual makes no mention of doing a hot lash on the inlines...only the V8's.
This article has me confused...
fordsix.com
Adjusting Your Valves
How to adjust your valves properly First, you need to determine if you have solid lifters or hydraulic lifters. Solid lifters were commonly used on the early 144/170ci motors, while hydraulic lifters were used on the later 144/170ci and all...
