I have been reading screeds of data from recent magazines on Ford Falcon XR6 Turbo verses Ford Falcon F6 Typhoon turbo lag. One has a nominal 4 to 6 pound boost, restrictive intercooler, GT40 turbo, and no lag. The other has the same turbo but a free flowing intercooler and 9 pounds boost. People really notice the turbo coming on with the F6, but not the XR6 Turbo.
There is technically very little difference in peak power, a conservative 330 hp verses 365, but there is a huge difference in torque, with something like 450 units on the XR6, but 540 on the Typhoon.
I have two observations. One, engines with restrictive intakes have less lag. Mainly,I'm guessing as pressure can build up quickly in engines with lower volumetric efficiency. Two, improved primary induction (ie better volumetric efficiency) increases lag, and creates a more noticeable progression between on and off turbo.
Can someone explain the likely changes in turbo lag given a controlled test on the same T3 turboed engine if one has , say, a restrictive 200 with log head and the other a 2V head is added? Take the turbo as the same trim, and assume the peak boost is the same at about 9 pounds. Assume a nice 264 cam, and about 200 hp, and about 250 hp with the 2V head.
How will low speed lag out of corners be influenced when a better breathing head is bolted on?
