how much better?
xt falcon
ok i was just wondering how much better an ultraflow manifold is compared to my redline manifold. and is it better because it is rounded which makes for smoother air flow compared to my redline which has sharp corners. also it looks as though they sit closer to the block from the outer most edge, has any one got a measurement of it?
thanks Aaron
Until some-one does independent flow tests of each runner compared to the total flow of each of the six intake ports of the alloy head, then no-one knows. Redline has worked well in the past, but the Ultraflow has some impressive numbers.
I tell you what. Some mainfolds flow huge numbers on there own, but once bolted up to a head with a carb, the total pckage can be awfull. Some runner cfm flows can vary by up to 15%. 4-bbl intakes for sixes are often much worse balance wise than the stock 2-bbl ones, but your running blind until you get flowbench numbers. Any mainfold that looses less than 20 % of the head blow when bolted up, and has less than 5% variance cylinder to cylinder, is a solid gold piece of hardware.
One thing has to be intake runner volume. If you got an aggressive cam, and a big set of primaries in a 4-bbl Holley carb, the bigger runner volume has got to be a minus.
