Hi falcon fanatic,
Engine vac is measured at the manifold, i.e., under the carb. If you have an automatic you can pull the manifold vac line to the trans from the manifold and check engine vac at that source. Normally speaking, you should see 15" - 18" at idle (Approx 600 rpm - in gear if automatic). This value will vary with altitude and temp (air density). Having said that, I find your current reading unusual. The numbers don't seem to conform to what I would expect for either a manifold or ported source. Manifold should be relatively constant, increasing some with rpm. Port vac should deteriorate as rpm increase. Your values 5" - 25" do not conform to either norm. Are you running long duration cam? What type ignition are you using? You say the car runs strong. What is your initial advance setting?
Very curious - Steve
