Timnmelinda
Ok Rings, Valves, or valve seals?
In our 200 (67 Mustang)
The car smokes more than just at startup, it is more or less constant, you can see it and smell it, however I have been behind many vehicles that you could see and smell it worse.
I am far from a master mechanic, If I understand a std compression test will tell if compression is low (which I have not done yet) but is there a way to determine without tearing the engine down, is it rings, is it valves, or what. I will be honest at this time I do not really wish to pull the block to do the bottom end, but would not mind yanking head for the top end.
Teach me, Help me!
Tim
Teach me, Help me!
Tim
