looking at picking up some parts (s/h) to put into the old XD over summer
COME racing Streetmaster cam - stg3 CLH-191
details: (i think)
Grind #CLH 191
Advertised Duration:
Intake 278 Exhaust 290
Duration @ 0.50
Intake 217 Exhaust 218
Cam lobe lift:
Intake .290 Exhaust .293
Lift @ 1.5:1
Intake .435 Exhaust .440
Lift @ 1.6:1
Intake .464 Exhaust .469
Lift @ 1.7:1
Intake .493 Exhaust .498
Lobe separation : 114
Stage3 COME racing head, flowtested to 300 hp (alloy) / set of alloy head extractors
Redline 4 bbl holley manifold / Holley 465 4bbl carb (freshly rebuilt) / rebuild XE electric dizzy
ok... so the current engine in the car atm is a 250 iron crossflow - its still healthy enough (no bad sound, oil use ~ <1 L over 5000 KM's, no smoke) - so I am not sure if I really need to rebuild it ? how will the alloy head affect the CR on the iron-head block ?
or should I just get it done anyway - maybe go for higher comp pistons @ 10:1 or somthing ?
The main issue however, is how well do you think this cam is suited to LPG - i have a impco 300A mixer etc that is currently on the car (holley 350) and it runs really well .... the car would be on gas ~ 80% of the time so its critical that the new parts help it get up and go while on gas !
will the stock fuel pump cope with this setup (for the small time its on petrol...) or will I need a bigger one ?
does the holley 465 need any modifications to run on gas (ie ... will the secondarys still open and stuff ?)
another question - should I get a new timing set for the cam, or try and get the one from the engine the cam is coming out of ?
new lifters are a definite yes ... ?
anyway... I will think up some more questions, in the mean time thanks
btw car in question = '79 XD 4spd
http://nforsa.8m.com/car/index.htm
details: (i think)
Grind #CLH 191
Duration @ 0.50
Cam lobe lift:
Lift @ 1.5:1
Lift @ 1.6:1
Lift @ 1.7:1
