Ricky:
The pedal changeover is fairly simple. Obtain the correct pedal assembly consisting of the two pedals, clips, nylon bushings, tension spring and mount and pedal stop. Remove brake pedal rod, then remove auto pedal from crossbrace. Install new pedals and clips. The tricky part is getting the tension spring attached to the clutch pedal. Mount the front tension spring bracket/adjuster, attach spring, pull pedal towards you and attach spring. Push pedal assembly to the floor and now attach the pedal stop to the rear of the crossbrace. Adjust pedal stop and tension spring. Re-attach brake pedal rod and clip.
At this point, you will have to decide whether you want to go with a stock equalizer bar assembly or a cable clutch.
