ozconv
Well I finally got things back together for another try. Here is the latest. Exhaust is now installed but the engine still won't idle well below about 1200 rpm. The best vacuum I can get now is about 15 at 1500 rpm and ignition timing reading about 48 degrees of total advance. The vacuum advance is disconnected and plugged. The harmonic balancer is a rebuilt unit from Mike. The cam is a 264/274 112. If the balancer is right, even with some all of the mechanical advance in at 1500 wchich it shouldn't be, the timing shouldn't be more than about 32 degrees. Has anyone ever had an issue with these rebuilt balancers?
All along I have suspected the carb so I rebuilt a 1.14 and swapped it for the 1.02 today and other than less throttle response, nothing changed. I also readjusted the valves once again before this latest try, thinking again that they might be too tight. I pulled the distributer and ran the oil pump with a drill between every valve adjustment. I stopped as soon as I felt the slightest resistance to spinning the pushrods and then only went another 1/8 of a turn.
Since swapping carbs and re-adjusting the valves made no difference, I am now suspecting ignition issues. The dizzy is an early 70s, pre ds1 with both vacuum and mechanical advance with the vacuum hook ups on both sides of the vacuum canister. The vacuum advance has been disconnected and plugged at the carb every time I have started the engine and attempted to tune it. I installed a pertronix ignitor II, pertronix ignitor II coil, and new plug wires also from pertronix. The plug gaps are set at 0.040". When installing the ignitor II one thing I noticed is that it comes with a plastic gage to set the gap between the module and the pick ups that are attached to the shaft. One of the holes in the module base plate is oval in order to allow adjustment of this distance. With the module as close as I could get it it was still maybe a little farther away than the included plastic gage.
After I shut the engine down for good today, I checked the number one spark plug and while trying to disconnect the wire, it pulled apart with the crimped connector staying on the plug and the wire coming off in my hand. The plug looked a little sooty. I guess my question is, could inconsistent ignition cause an engine to have lower vacuum and run rough at lower rpms? Would it also require way more ignition advance than should be necessary? I am starting to think that I should go back to a stock cam as I am running out of ideas.
