I have finally gotten the engine together and been through several folks now and still the car will not idle normally. It is a 250 with the aluminum head, intake, a CSC-264-10-DHS cam, roller rockers, dual outlet headers, bored 30 over, 390 Holley, Electronic dist.
When I start up it idles in park(automatic trans), if I let it warm to 190 degrees it will go into drive and then I need to instantly hit the throttle, then it will kind of idle. Then next time I come to a stop it usually dies and will nearly always die at an intersection. I have taken to driving like it is manual shifting into N
The idle is set around 800-900(guessing no tach) in drive. Does anyone have any ideas on how it should run other than not? It has been checked extensively for vac leaks, none. Valves have been adjusted several times, fuel, floats have been adjusted several times. Any ideas?
Also does anyone know where I can get the cam card as I did not seem to get one when the parts came, or how to get it to run "normally?"
I have about had it and am having thoughts of selling the thing. Any help would be very much appreciated.
Jim Reese
Jim Reese
