theguitarist
Recently finished swapping out the points for the Pertronix Ignitor 2 system with the Flamethrower 2 coil. Earlier I had been running it with the Flamethrower 3 coil but it fried the Ignitor and sat for 2 months while waiting for Pertronix to replace everything under warranty.
Now she runs, but she won't start consistently. When it does turn over she runs just fine, but it takes 10 to 12 tries to get there. I pulled the spark plugs to widen the gap to .40, as was recommended earlier in the forum. There was quite a bit of corrosion so I sanded them clean with a sander drill bit. Now there is no change. She will still start and run fine after several tries but it's not reliable. Maybe I should just replace the spark plugs? As always, any ideas help and I will finally get some photos up by the end of the week. Thanks!
