Ignition module
8) i would say that the dyna-module from performance distributors is going to be equal to the chrysler gold ignition module. they have similar rpm ranges. the big difference between the two is that the gyna-module comes with the coil and a resistor for the street. if you need the higher rpm range, then you dont use the resistor.
