I know this has been done quite a number to times, but I am making a good guide for me (and for others to read up on in the future) as I replace my Mechanical fan to an Electrical fan.
the reason I want to convert to mechanical fan is here in AZ I travel through traffic all the time in the city, and at idle the mechanical fan won't pull enough air to cool the engine down and my AC. usually I just shut off the AC and swim in the 110+ heat. well I'd rather not.
First I plan on upgrading my 60amp alt to a nice healthy 100-130amp alt, and get rid of the anameter and external regulator
Anyone have a plug and play setup? link will help (electrical blond here)
Next I'll need a Fan, or fans... I'm thinking I would like 2 electrical fans, reason behind is I won't need the 2nd one during winter, and I can save load on the electrical system, and last fitment of the 2 fans let me get deaper fans. My radiator surface is 17Tallx16Wide and I have roughly 2.5 inches distance to my water pump pully. My restrictor is 2.5 inches, I have to find a fan that can fit between my water pump pully and my radiator without touching the pully. BUT If I offset my 2 fans I can safely go 3.5 inches with more room to spare at most areas that I think the motor will be.
I'm thinking of 2 of these fans. 9inch Electric Fan @ 1550 CFM
control module I would Like to step up the fan's speed as needed, not a "on/off" but low-med-high kinda operation. both will run the same time initially
I found this "Flex-a-Lite" kit that sounds like it should do the trick (or even just a med/high is fine)
for these two mods to the electrical system I should be able to aleviate much of the load under the just from the alt upgrade, and the fan will give mpg and HP increase. and the steping module will help negate spikes in the electrical load.
I need help finding or seeing things I don't know about. Thanks guy's this is awesome :mrgreen:
