falcon_master
Hi everyone. I recently got a PerTronix ignitor electric ignition so I don't have to worry with points or anything like that. My question is I know if you leave the key on it will fry the module. My idea to fix this so I can have the key on to check things without destroying it is what if I bypass the ignition circuit and ostead of having the resistor wire go the the stock switch it goes to a under the dash toggle style switch. That way I can keep the key were ever I want as long as toggle switch is off the module won't fry. And the starter will still work off the stock switch
