Hey guys
Well I’ve tried just about everything…
I have a duraspark dizzy, blaster 2F coil, and MSD 6A box. Well, the coil began to ark uncontrollably between the coil tower and the (+) and (–) terminals. Then, suddenly, the entire ignition system shut down. I bought a new distributor because I found that if I moved the dizzy a little it would fire up for a few seconds. Well, I put that in, and nothing happened. I then bought a new coil. Still nothing. Does this mean that my 6A is bad?? I now it does look like that, but I find it hard to believe. I’ve only had it for 6 months and not even during the hot summer months. Anyway, I’ve got fire all the way to the coil but not to the plugs. Does the spark travel from the coil to the 6A AND THEN to the distributor? Because I’ve gotten the coil to ark between the tower and terminals again but still no power. I’m positive that the dizzy is in right. I set it on TDC after the intake valve closes. And I know that I am 180 degrees out because it is not shooting fire out of the carburetor. I don’t get it. Will the car run with the valve cover off?? Because I am trying to get it to fire before I put it all back together so that I don’t have to tear it all back down again.
I really appreciate you guys’ help!
