stu in wichita
This is my first inline 6 project, but I've already figured out how addictive these things are.
I've ended up with three engines for my 61 Ranchero - '83 model 200, a '70 model 200 and a '64 model 170. I'm rebuilding the '70 using the '83 head, but in the meanwhile, I'm going to run the '64 engine. All these engines are similar, but I know Ford made lots of changes along the way. I need to figure out which external engine parts I can mix and match. Most of this has been discussed in other posts, but it would sure be helpful for newbies and budget builders to get it all nailed down for easy future reference.
1. Starter - Do all the high-mount starters interchange? One thing that might make a difference in the starter is the flywheel size. I assume the low-mount is totally different.
2. Fuel Pump - The fuel pumps on all my engines look similar. Should I be able to use any of them, or what differences do I need to look out for?
3. Distributor - I know there are two different size openings in the block for the base of the distributor, plus a difference in the oil pump drive shaft. Did both these changes occur in the same year? I know the LOM and Duraspark versions bring up lots of other differences, but for now I just wonder about the physical differences.
4. Water Pump - Short and long snout - other than that, is there any difference? As long as my pulleys line up, can I use either one?
5. Exhaust manifold - Are they all interchangeable (except for the big "can" style on the later engines)
6. Crankshaft Pulley/Harmonic Balancer/Dampener - I've heard that the earlier engines just had a solid pulley. Will the later ones work on any year engine?
Thanks in advance for clarification on these parts.
-Stu
-Stu
