Howdy Back Tom and All:
IIRC the only early 1101 that is a fairly direct swap to a '65/66 200 is the 1101s from '63 and '64 ford cars that had the 233 engines. These are SCV carbs. FYI- the 1101s were adapted for use on other vehicles, cars and trucks, with 240 engines. The only 1101 that was a non-SCV carb was the 1969 1101 from a Mustang with a 250 optional engine. It was the last to use push/pull linkage.
On the linkage adaptation take a look at the '80 head you will be building. If the, "Powered by Ford", valve cover is there it will have several attachment bracket for over-the-valve cover linkage. A fairly easy solution is the linkage and brackets from a Maverick/Comet. If you are junk yarding, get everything from the gas pedal to the brackets.
PS- I've use a variety of 2100s on 200s and 250s and rarely saw a decline in mileage. The exception was a 1.33 on a 250, but great power.
None "Slobbered". Any loss of MPG will be more likely associated with over use of the GO pedal. Re-jetting was seldom needed either. Accelerator pump, idle and power valve tuning were the only tuning needed. Maybe bcowan can elaborate on his experiences with 2100 swaps to a 200 engine.
I played with several Holley 2300s with less satisfaction. WSA111 did internal tuning and gets good results with the 2300s. As you know, He's good help.
Keep your progress coming.
