AFTER LOOKING AT AS MANY PICTURES AS I CAN FIND ON THIS WEB SITE I'M STILL NOT SURE IF I HAVE THE LINES HOOKED UP CORRECTLY. PLEASE TAKE A LOOK FOR ME AND SEE IF YOU CAN HELP.
IN THE FIRST PICTURE DO I HAVE THE SMALL ALUMINUM TUBE (HAD A BRAIDED CLOTHE) FROM THE CARB GOING INTO THE WRONG POINT?
COULD IT BE THAT IT NEEDS TO GO INTO THE EXHAUST MANIFOLD HOLE YOU CAN SEE IN THE PICTURE?
IF SO, WHAT HOOKS INTO THE TUBE INLET ON THE SMALL COVER ATTATCHED TO THE EXHAUST MANIFOLD NOW?
TRANSMISSION VACUUM MODULATOR IS PULLED FROM INTAKE VACUUM? CORRECT?
THESE PICTURES ARE OF THE LINES THAT I HAVE, THE FITTING ON THE LARGER ONE DOES FIT THE HOLE IN THE INTAKE MANIFOLD AND I WILL NEED TO FAB THE REST IF THIS SEEMS CORRECT.
THE SMALL LINE IN THE SECOND PICTURE, I'M NOT REALLY SURE.
AGAIN I HAVE THE VACUUM TO THE DIST. AS YOU CAN SEE IN THE FIRST PICTURE. ANYTHING OUT OF PLACE?
THE SMALL FITTING ON THE TOP OF THE CARB IN PICTURE #1 SEEMS TO BE THE SIZE FOR THE HOSE ON THE SMALL TUBE IN QUESTION BUT I'M NOT SURE WHERE IT SHOULD LEAD. IF I LAY IT AROUND THE VALVE COVER IT COMES TO THE OTHER SIDE OF THE ENGINE ABOUT CENTER OF THE VALVE COVER.
[/img]
[/img]
[/img]
