Jetting for the Weber 34DGEC (also known as the Solex 34TEIE) and 38 DGAS and its variants is based around the
1. emulsion tube choice,
2. the parent engine Cubic Inch Displacement and Volumetric efficiency
3. the resulting horsepower level
Everything uses the F50 emulsion tube, so its an easy calibration. The normal US market 38 DGAS uses the Essex/Cologne V6 135 to 138 hp 27/27 mm main jets, and 142 to145 main jets with 185 air corrector and 45 idel jet forlittle engines, but a 50 or 55 will work better on a 250 engine. The 2.5 mm needle valve and that will give you got basic results.
The jetting for the Jeep 4.2 liter 258 will be closest for the 38 Weber on a 200 or 250 Ford. Other jetting info comes from
the 2664 cc 2.7 liter PRV 60 degree V6 Renault R30
the 1990 cc 2.0 and 2294 cc 2.3 liter Cologne 60 degree V6 at 92 to 108 bhp net, Ford of Europe 2.0 and 2.3 Taunus/Capri/Granada/Sierra
the 2793 cc 2.8 liter Cologne 60 degree V6 at 135 bhp net, Ford of Europe Granada Mk II/III
the 2994 cc 3.0 Essex 60 degree V6, 138 bhp net, Ford Capri 3000GXL, 3000 and 3.0S, Relient Scimitar GTE, TVR 3000 M
Others have modified F7 and F6 emulsion tubes to create an F-This emulsion tube, and then test and tune the air corr and main jets. So I'm cerain you'll get great results with the 38 DG series carb.
As for the too small 32/36 Weber with stock box emulsion tube jetting from Pierce, you can regig it if you use some 258 Jeep smarts.
From uptillnow on page 3 at http://www.jeepforum.com/forum/f8/weber ... ndex3.html
Now, with that said the 32/36 can be made to operate a 258 Jeep. The jetting that seems to work for all around performance is a .75mm Primary idle jet and a .60mm secondary idle jet. Ussually both main jets are 1.45mm and a primary air jet of 1.70mm and the secondary air jet at 1.60mm.
Then, the trick is to have the engine idle at zero vacuum at the "S" port or spark port and the idle speed screw absolutley no more than 1 1/2 turns in. Then the timing is set to 8-10 BTDC, some go more and some go less. The idea is to have an idle speed and no pre-ignition.
