HUMINA
Active member
Looking for a little help in understanding something about running an engine lean. My understanding is that running an engine a little lean (maybe around 15 or 16:1 ratio) will result in a hot running engine.
How lean can an engine be and still run even if it isn't running well? Basically what is the air to fuel ratio limit where combustion won't happen. At some point it seems that running lean would result in an engine running cooler because there is excess air.
If heat (and less power) is the concern with running lean, could an engine be set up to run extremely lean in combination with water injection to help keep temperatures down? Then, if the engine and water injection are being controlled, at WOT the engine could go back rich for power.
I am sure there is a large hole in the idea ... just having trouble finding it at the moment.
