hydraulic non-oiling lifters for most applications. the main reason to use oiling lifters is if you are putting a double-roller rocker assembly on your 200.
"the Hydraulic Lifters you would need to use is determined by the Rocker Arm Assembly you are going to use.
The OEM/Stock lifters for all Ford small block six 144/170/200/250 are non-oiling, the rocker arms are oiled through the rocker arm shaft. Some aftermarket HiPo rocker arm assemblies require oiling through the pushrods .
