Can someone please explain the different inlet systems and the pros and cons of each (single lpg throttle body, plenums etc.) in blow through systems.
I can basically understand how the single lpg throttle body blow through system works but how do the twin tb and the plenum things work. I dont care about draw through systems, I will be using blow through for sure!
Can someone tell me exactly what is going on in this engine;
http://www.fullboost.com.au/cars/featur ... n_pg1.html
What are in take runners? Are they the small pipes that the inlet manifold bolts on to? Is this motor a single throttle body? Is that it at the start of the plenum chamber? Arrr.. Im confused.
thanks again
thanks again
