ok heres the scoop as from my past posts and all. the engine is a 1980 200 ci. stock rebuild with a CI 274/274 112 cam. jeep. 4.0 valve springs .adjustable rockers ,port work, backcut valves. unshrouded chambers. approx. 8.7 c.r. . the engine has about a 1000 miles on it since rebuild and through all my tinkering with getting it timed right. ive noticed the plugs are light tan almost a bone white color and its caked on the plugs. chiping off when you rub the deposits with your fingernail.
also my distributor sounds like its about to come apart inside. its sounds like a clikc click clack........clikc ..clikc....click clack.... could this be bad /old/defective advance springs. and on another not. the car still has the stock canister type manifold. no internals its just empty. when i rev the engine all the exhaust sound is coming from the engine compartment not the exhaust. and from another standpoint when i was behind the car listening to the exhaust i covered the exhaust pipe and the idle cleaned up . is this bc of my stock exhaust sytem with only about 3 ft. of 2.25 pipe leading into a flowmaster 44 and back out the stock dia. tailpipes. could anyone help with this. i know it might seem as if i am being obscure about my questions.but someone has to have had these things happen to them. if anyone could help it would greatly be apreciated.thnks
