Mexican Fairmont Differences
Stormin' Norman
Departed Member
As I already mentione elsewhere, I've got a nice '79 Country Squire Wagon, 302-V8 Automatic C4, A/C. I have to change the motor (I dropped a screw into the carb and blew the Passenger Head) and lucked out finding a nice '78 200 CI, Automatic that has only 20,000 miles since a Dealership rebuild of both the Motor and Trans.
Mine is completely stock from Mexico. It comes with a Bosch Starter, a Distibutor with points, no headrests on the front seats, AND a 3.07 rear-end, not 3.08. The North American tag would say WGX-etc., but mine says 4314 then 3.07. I've driven in snow and always had good tires, but I'm sure its not a Sure-Track type (Posi-Trac?).
My Door Tag is completly different from North American cars, and for the Axle (Eje in Spanish) it says "A", which would be a 3.08. Searching on the web, I found that this axle 4314 3.07 was used in a Checker Cab during 1977.
I've checked the web and this forum for the last 4 days and found lots on rear ends, even a site covering Latin American Door Tags. They don't list the specs equivalent to the Codes.
The rear-ends in both cars are good. The problem may hit me when I need to use the driveshafts or send one to be re-sized. I was hoping I could prepare myself before I got the other car and send mine out to get modified.
The other issue is whether the C4 from my V8 will bolt up to the 78 200 ci engine. I read somewhere that the splines might be grooved differently.
Can anyone point me to the right resources? We're hitting freezing here, and I have to do the swap outside. I can pull the motors and tranies in 2 days (I'm alone) and pop the finished assembly in the next day, but we've only got one or two more weeks above -10C in daytime. We're already hitting -12C at night. So I want to get this done before the -20's come along. Thanks
OK, as the transmissions are similar era, the input spline count should be the same. There could be some minor internal differences, but nothing that will impede function.
I thought the Fox bodies had a front subframe with the motor on it, and you could just lower that down, then lift the donor car off the top. I'd suspect that the driveshaft from your donor car will work if both are the same wheelbase.
