fast64ranchero
Well no pics yet but I'll give you all some motor info, the head is still at the porters should have some flow numbers in a week or two, the bottom end is coming along slow had to ordered a diff set of rods for it, which is holding up the crank from being offset ground
the engine will end up around 269 inch's and if any of you want to try and build the same motor I'll give up the needed info, my motor has manley 5.905" (Mitsubishi 4G63B 93 and up) rods, you could get by with stock rods at a low boost level, the crank will be offset ground to 4.1 inch stroke, maybe 4.125" we'll see when it's done, pistons are on hold till the crank is ground, this motor will have a terrible rod ratio, but R/A has little effect till 5500 rpm or so, now if you want you could go about this alittle diff. one could use Jeep 4.2 rods stock or Eagle makes H beems 6.150" which will have a better RA 1.56 or so, and have pistons made or, Manley also make the Mitsubishi rods with a 1.771 big end, which means a stroke of 4.2 could be done, I choose the 1.88 big end rods as I am concerned with that small of a rod journal on a cast iron crank under 15lbs of boost, well there you go that's it, for now I'll post pictures when I get my parts back,
