So I tweaked on the engine some today...
I installed the correct PCV valve, and put in a new set of plugs (BOSCH Platinum) without changing the gap on them. I had them set to .50 before... running MSD 6 and DII dizzy...
These two things did wonders for the idle... it idles much smoother with the plugs at a smaller gap.
But, I am still only pulling 12 inches of vacume with this 270 cam, and Schnieder says I should be getting 16 inches at 700 rpms... I am getting 12 inches at 900 rpms... drop it to 700 and I only get around 10 inches.
I did not have the timing light today, so I did not adjust the idle or timing at all?
I changed the intake gaskets and header gaskets and have no leaks that I can find, I hope not anyway, I have changed them twice now.
The gauge and the idle are steady at 900 now, no surging?
The engine still runs hot when warm and cold when cold?
I am going to start calling around looking for a mechanic who knows Holley carbs and see if I can get some help on this one, too long now with the exact same problem and no discoveries.
