kirkallen143
Howdy,
Does the DSII give more spark or is it more controlled spark over points, and is this using the standard coil? I am converting over now and wondered if I needed to buy a higher voltage coil...anyone changed coils, from low to a higher voltage while having the DSII installed already? Just needing a little more spark with my turbo application. Would using a coil such as a TFI running a full 12 volts have any advantages than the higher voltage coil running thru the ballast resistor? Sorry about the too many questions, they all popped into my head at once. Thanks again as always everyone.
Kirk Allen Jorden
Kirk Allen Jorden
