New, never installed part, with USA points, condenser, rotor, and vacuum advance
Ford 6 cylinder ignition distributor for 1968 through 1972 Mustang and other Ford vehicles. Dual advance (centrifugal and vacuum) which works with NON SCV vacuum carburetors (full ported vac carb).
New, high quality, well-made reproduction. 2017 date code WAI DST2613 unit with all new components including USA points, rotor, condenser, and vacuum advance (tested, holds vacuum). This unit is set for typical ‘68-‘72 vehicles with a 170, 200, 250 cu in six motor.
5/16” hex female drive.
Assembled, adjusted and lubricated. Ready to install and run.
This is Not a Load-O-Matic Distributor
$95 plus 12.50 shipping
ships to USA only
ships to USA only
