Oh dear, I looked the other morning underneath my Cortina 250 2V to check on my rear main seal leak. Its got a alot worse rapidly and now I dont think I can drive it safely.
I have a few questions as Im fairly new to this hands on work (pulled engine out and one in only once myself).
I am not too dismayed about pulling the engine out after only about 5000 ks on new engine to replace the main seal as I want to replace the cam also and it will probably be easier with it all out anyway.
This is with one exception if it leaks badly again it will have to stay in the garrage for a very long time maybe even indefinitely. So any advice I can get on what I can do to do a better job of it please feel to tell me (would a latter neopreen seal fit?) (whats a good gasket kit)
I think I may have to cut and remove the headers as they do not pull far enough away from the head to pull out the engine. Ive got an original heavy duty 2V clutch (different from the clutch fitted to the log heads) from Tilleys to fit as well.
And just one other question should I replace the moly rings with new ones. Ive only done low ks (5000ks) since rebuild, but Im thinking while its out, should I re-hone it and fit new rings?Or is this unnecessary. I will be reving it to 4800rpm occasionally next time the engines back in.
Any advice would be valued.
Cheers Tim
Cheers Tim
