yup I did it... I bit the bullet... then sat on the kit for 2 months... my dad found out and gave me a garage and a spare car to drive while I install the kit... I have till the end of august... fingers crossed.
the kit is complete, it's from AFI and they made a custom wireing harness for me, originally I wanted an electric fan control but after having over heating issues I decided to cancel that and go back to my mech fan.
the kit uses a GM OBD1 box, they dummied it down for my car, it will be controlling timing so my DUI is off getting converted to a 7pin module over at performance distributors. in the mean time I'm installing the other components and thinking what I want to do with wiring... I need to clean up some of the existing stuff as it looks horrible right now.
the tune I have no idea, I couldn't afford the extra $400 option to make it a programable box so I'm at thier whim on the tune. also the spare car won't be availible at the end of august. so I gotta get it running... hopefully.
http://www.affordable-fuel-injection.com/
the TB is huge, much bigger than my current 350cfm carb, it does require a return line, so i'll run one back to the filler neck of the tank. the kit includes everything except time and the return fuel line. AFI offers to tune the car and send out a new chip any time. I'll run it on the dyno for numbers but more importantly the tune and what it's doing at any RPM range. then also road tests using an OBD1 monitor for my laptop.
http://www.aldlcable.com/ has the cable I need to collect the data I need to give AFI, along with the dyno results.
it sounds pretty straight forward, I just hope I'm not that pioneer which gets scalped.
the end goal is drivability and dependability on this car. I spend too much time working on power and MPG that it got away from me, so with his TBI kit both are welcomed, but I really want a travel car that can climb and roll on the hills without a break to re-tune every elevation change.
anyway's thought I'd start a thread and go through the ???'s of "what's this do??" kinda thing when it comes up... I'll post some pictures of the TB next to my old carb.
return line I'm kinda on the edge, either ron morris sending unit, cleanner and out of the trunk or weld a bung on the filler neck...
http://www.ronmorrisperformance.com/miv ... ding_Units
A six :smash: :smash: :smash: :smash: :smash: :smash: hit
