Hi, I searched the forum a bit before posting this message. Here are the symptoms.
1. I noticed what I believe was an exhaust leak for about a month. It kept getting louder so I figured I better find it and fix it. However, before I could, it got really loud on my way to work. After work I went out to start my car, it turned over then began to run really rough and coughing black smoke. That's when I saw the exhaust coming out from the doughnut at the exhaust and manifold connection. I bought a new doughnut and bolts and repaired this problem (quite now). But.
2. Now the car still won't start properly and when it does it runs extremely rough and I noticed that the carb is spraying gas everywhere. It was doing it the night after work when I tried to start it as well. It wasn't as pronounced then, because, I had the air cleaner on it.
Up to this point other than the exhaust noise the car ran fine. It had a bit of a skip at cruise, but was fine under acceleration and idle. So, this is my situation. Can any one help.
My car is a 1966, Coupe, I6 (obviously), Autolite 1100 (Holley rebuilt 3 months ago), tuned up about 2 months ago with new wires, cap, rotor and plugs. I also have a pertronix ignition that's been on the car for a year. Thanks for the help. Stranded.
