Howdy Mike:
You asked for advice, so.....
You might want to consider rebuilding your stock OEM Autolite 1100 carb yourself. A kit is about $20.00 and instructions are easy to follow.
First, assess the tightness of the throttle shaft in the carb body. A loose shaft is a greater likelyhood if you have a standard trans. Carbs on an engine with an Auto trans are less likely to show wear in this area. If the shaft is relatively tight it is a good candidate for a cleaning and rebuild. If the shaft is sloppy it is a good candidate for a core trade in. Rebushing a throttle shaft is not a job for a first time home rebuilder.
A new rebuilt carb may or may not be a good carb as it comes from the store. Many rebuilts have missmatched or misaligned parts, debris or clogged passages. Getting a good, ready to go bolt-on is about a 50/50 proposition. IF you go that route, save your receipt.
IF your old carb used to run good, it is likely that it could be brought back.
AKT a faulty ignition system is often the cause of carb problems. Make sure your ignition is in tip-top shape before assessing the carb. The most likely sources of carb problems is a bad Spark Control Valve (SCV), a shot accelerator pump, vacuum leaks, a faulty vacuum diaphram or a sticking advance plate in the distributor. OR a combination of any of these.
Check for vacuum and/or gas leaks. Check for open filters and make sure you have fresh gas for the evaluation. Make sure the exhaust is not plugged.
A carb kit, a can of spray on carb cleaner, a clean, well lite place to work and a few hand tools are all that is needed. Once disassembled, spray the cleaner into all orifaces and let it set for awhile. Be sure to use safety glasses and old clothes when spraying. Be sure to work over the choke area thoroughly. The hot air intake in the choke is the source of much of the dirt and contamination inside your carb. Once the top is off, don't tip the body over until you've identified the holes with check balls inside of them.
With an Autolite 1100 there are very few pitfalls. It is amazing what a clean carb with a new accelerator pump and SCV will do for your carb rebuilding ego.
Pony Carb sells a very good rebuilt and modified Autolite 1100. They are quite a bit more expensive then regular rebuilts, but some say they are worth the money.
Keep us posted on which way you decide to go and on our progress.
