if I put a 170 head on a 250 will my compression increase?
I also have heard that puting the 6' rods out of a ford 2.5L 4 cylinder will help too.
I will probably use an isky cam that runs 1000- 3800 rpm
will i want to advance the timing to make this work?
I think that i will use the webbers of the old 911 porche6 cyl
these are 3 barrels so it would be an individual runner system one barrel per cylinder with 2 carbs so it should be easy to tune.
I want to use this in a 1968 Intranational Scout with a T18 or 19 tranny (not sure which), 33' tires, and 3.50 gears because I want to cruise on the highway at 75 mph.
