Ok so I decided I could put in a new carb, hoses and a new vaccum advance myself. While I had everything off, I went ahead and painted the engine as well. So I got everything back together, started up the car and gas was leaking everywhere!! I shut it off, tightened the fuel line and tried again. This time it ran but was real rich (white smoke from the exhaust etc... So I figure it was a fuel/air mixture setting on the new carb. But then I saw a puff of smoke up by the altenator/battery. I turned off the car right away.
I noticed that there was still a small amount of gas leaking from the carb. So I re-tighted, checked out the altenator and battery, everything looks good. I also turned the idle screw about 1 full turn (before starting). So I go to try it again. This time nothing!! The starter motor makes a noise but the engine won't turn over
During this process, I did clean off the altenator, and I did use some degreaser on it. But I put it on a cloth and rubbed it on. Also the wires to the altenator are kind of old and one of the connections is showing an exposed wire. Can I test the altenator somehow? Any thoughts? could it be a solonoid? I cant see how the carb/fuel line/vaccum advance would effect the electrical system. I do have a pertronix module... and one more thing the dummy lights on the dash, One says oil and the other says ALT. They both are on. Oil level is good, I dont think these lights were on the first 2 times the car started.
Thanks
Thanks
