LameHoof65
I am fairly excited about this and I don't have the knowledge or expertise in this area, but----I think I found a workable SEFI Intake that will adapt fairly easily to this 200???? Need feedback though....the intake comes off of a 96 Escort LX 1.9 litre 4 cylinder...What I like about this manifold is that the plenums are not fused and they line up fairly close to the end of the 200 plenum only one of them is a problem. But here is some more good news the Air Intake resevoir is a straight round alum tube so if you splice this thing and put two of them together with 3 plenums ea. end to end and manipulate the center section to get the distance there, you will have an almost perfect intake with separate tubed alum. plenums that look fairly flexible. Wait it gets better, the flange on this thing can be cut machined and manipulated to assist with the lining up of the port to plenum connection.. at worst you may have to cut the individual plenums and reweld them so they line up on the port to plenum flange.... Any way I pulled one and brought it home, got the throttle body & and cut the cable, most of the FI connectors and harness and the manifold along with the fuel injectors. I think this is a good solution to the log be removed and replacing it with this manifold.... the exhaust flanges will have to be removed to but then a flat piece of aluminum about 2 inches thick can replace that -- easy enough--- what do you all think?? If it sounds like a go to you all I am going back and pick up another intake I spied today...before I left the yard. Also, I am thinking I can connect this thing to the MEGAsquirt system........any feedback will help me.....
: :roll: :idea:
