Reassembling my 65 200 engine compartment and I plan to leave the original A/C compressor off. The humongous bracket for the A/C had the alternator mounting points welded on, so I ordered a new set of alternator brackets for non A/C. I assume the L bracket with the adjusting slot mounts to the upper left water pump bolt, but I can't figure out how the triangle bracket mounts. Any help, or pictures?
Also, this arrangement seems kind of flimsy. The old bracket on the A/C mount had holes fore and aft for the long lower alterator bolt. Is there supposed to be some other support for the back side of the alternator on a non A/C engine?
Here's what I've got:
http://johnsmustang.com/Catalog/602/
thanks for any help.
