Well, I'm at it again. Just got a new Holley/Weber 5200 for my '65 Mustang and have read quite a few opinions, tech articles and so on. I understand that the recommended positioning of the carb is with the fuel bowl facing the front of the car.
I am going to machine my own adapter design so position isn't an issue there. However, with the carb sitting on a mock up positioned with the bowl at the front, the water choke heater fitting interferes with the valve cover, the linkage is in a real difficult to hook up place. In other words, the only advantage to this position is the bowl location.
I don't plan on auto crossing, slalom or road racing. How much negative performance will I expect to experience with the bowl pointed towards the valve cover? With the carb positioned that way, the installation will be MUCH more efficient and neat.
Next question, where do you hook up the electric wire that comes out of the choke? And finally, will a tee in the heater hoses work to run through the choke heater or will it affect the operation of the heater core?
Advise please.
CrashBob, wannabe mechanic
Advise please.
