Greetings,
I was having some almost-overheating problems after a top end rebuild that seems to have been a bad tstat. Now that it seems to run at a more normal, (but not as cool as it did previously), I have a new issue that I need help with:
When the temp starts to climb near the 3/4 mark, the Tstat obviously opens & the temp starts to go back down. That is good. But when I stop & turn the car off & leave it off for a few minutes, the gauge goes all the way HOT when I start it back up. Yes, it does drop again after it runs for 1 or 2 minutes, but that's 1 or 2 minutes where it IS HOT. What's up with that? Is the engine really that hot ? Is this something to worry about ?
What is the acceptable temperature range that these engines can safely run at? I will buy a real temp gauge tonight & install it. Any suggestions as to where to draw the reading from? Can it use the sensor in the head for an accurate reading?
Thanks,
David K
1963 Comet Convertible
Seattle
Thanks,
David K
Seattle
