Fred C
Hello All,
I got the engine and transmission installed in the 63 Futura Tudor and have run in to a couple of snags and wanted to see what I can do.
The 200 with a C4 transmission has a set of Scott Drake dual headers but there is a issue with the starter fitment. We installed the starter but it is such a tight fit that the header would have to be removed if the starter had to be replaced. This is 3 bolt Starter.
Is there a another style starter I could use that would eliminate this problem? It also seems that the starter being so close to the header that it may get too hot. Can that section of the header be wrapped with some header insulation for heat or something?
I've also installed an aluminum radiator but the oem fan blade is too close and i don't think it will work. Is an electric fan set up what I need or is there a flex fan that could be used?
Your input is much appreciated.
Fred C
Fred C
