Just wanted to let you know that I got my new valve springs in without to much heartache last night (took a few hours for a first-timer). Once I realized I could get more coils into the compressor to give me more room to get the keepers in and out, it was much easier .
Still have to run her on the open road to tell for sure, but it sure seems to run better. I'll no more once I can open her up a bit.
I was hoping that getting the new springs in and having the valve adjustment right would yield a better compression reading on the #1 cyl. Unfortunately, that's not the case. Looks like I'm down to either blown head gasket (no other symptoms like overheating or bubbly coolant though) or a wiped cam . Still trying to track down a dial meter so I can check the lift.
I also was having an issue with low fuel pressure. It was reading only about 3psi and my Holley needs more like 6-7. I put a carter electric pump in back by the tank and that seems to have done the trick. it's back up to 6-7ish where it belongs.
One bite at a time...
