nitrous on 200
crs93and66
I have a 200 66 mustang I would like to run a small shot of nitros under 100 hp prob 50 , it is a stock engine, what would be the best kit for this, any help would be greatly appriecated
thanks
chris
is there a link on there i'm not seeing?
i didn't see any buildup at all on that...
a "sneaky-pete" system should easily support a 50-75HP shot of nitrous
they're pretty cheap too
Hi Chris.
I'm using an Edelbrock nitrous kit, it's relatively cheap, and the materials and harness are better quality than the others out there.
Since I had modified the intake for a 2BBL carb, I used a NOS 2BBL nitrous plate.
The most I have sprayed is a 75 shot , my engine, even though it has cast pistons I beefed it up a bit with ARP head studs, and con-rod bolts. Also an MSD ignition and an electric fuel pump with regulator.
Also take into account that the tune is the single most important thing when using a power adder, get the tune right and the car will fly, get it wrong and....well it could get ugly.
alex
