hey
Just investigating off set grinding cranks as iam thinking of ofset grinding a 200 crank.
From 79.55mm stroke to 93.47 which is the same as as the bore for a square engine and giveing a capacity of 3.921L or if i go 94.47 and run the engine 40thou up3.971L which i think is the same size as the 3.9l and 4l engine's.
now whould i be better of seting a 250 crank back then a 200 up and how much can you off set grind a crank with out weaking to much.
i realise this ant cheap ether but iam wanting to build the ultament xflow n/a and will try and chase down one of those twin cam heads hopefully in the next year or 2
now iam told that if i use honda rods i stroke a 200 out to 222ci
or if i use 1600ford rods i destroke the 250 crank.
or i can use a 221 engine but not sure if 221 will have the twin cam head option.
anyways with the twin cam head and a square or slightly under square stroke to bore i should be able to spin the old 200/221/250 to around 9000rpm
mark
mark
