i am gonna shoot my engine dynoist.....
:x :x :x
today was to be the final tuning session for the mighty sohc i6.
last week we were carring out final tuning and power runs,, in that session, we discovered that the injectors were maxxing out (read 99% duty cycle) and that the pump wasnt supply enuf juice either. so i said hold off i'll get an extra 1000hp fuel pump 2 large fuel filters and a good suge tank.
he said "rightio no worries see you next week"
i rocked up sat morning, gave him a hand installing all this stuff,
this morning he had a crack at tuning it, at first the fuel mixtures were bloody rich (8.6 to1) which fouled the plugs, new set of plugs went in.
then the tune started... 5500rpm reading 48% on injectors duty cycle with 32psi on board making 753hp.
5800rpm- my self imposed rev limit. 51% duty cylce 767hp.
the engine was design to rev to 6100rpm with 35psi on board.
he called told me the excelent news he said he reckon it can go to 6100 easily and support the 35 psi, he said do you want to try it and see if we can crack the 800hp barreir? i said... after alot of umming and arring OK... big mistake.
the tuner fellow done his adjustments of reseting the rev limiter but didnt raise boost pressure (stayed at 32) then gave it a power run.
throttle snapped open, engine reved cleanly right up to 6000 then started to lean,, so he re-adjusted maps and base fuel pressure. he said it make 782hp.
i asked is the motor being stressed with this he said with a resounding voice... no.
so i gave him permission to do it again,
not half an hour later..... he called me and spoke very quietly,, i knew something went wrong. he started to stutter and beat round the bush. i told him to get on with it and tell me.
he said ans i quote
" well,..... the dyno screen is reading 42psi rpm 6700rpm and ur power figure is 912hp........but the block now has 2 gapping holes in the side"
i cut him off and said in a fit of rage, charlie..... throw it away, THROW THE BOTTOM END AWAY DELETE THAT DYNO GRAPH AND I DONT WANNA HEAR ANY MORE ABOUT IT".
at that point i hung up the phone. furious!!!.
i calmed down and went round and seen him.
he was extremely sorry, he told me his wife spilt hot coffee on him as it was reaching the end of the rev range, and then after that he dosnt realy recall what happened except that he heard 2 loud bangs.
so now i have to get another bottom end and re-start it all again.
i was hoping to have the car readyfor christmas but alas that will not happen.
i will not be taking any action against charlie, though, as he has done all my dyno time for free and has offered to do all my dyno time in the future for free as well. which far outweights the bottom end cost anyways (3k).
i dont realy blame him anymore, but i am still very annoyed BUT THEN AGAIN 912hp is fudgen unbeleivable, and now i am more pissed that i told charlie to delete the graph then i am about my bottom end!!! lmfao.
f**k i am a dumb sob, i should of been happy with 767hp as the original goal was 740hp.
aw well shit really does happen.
cheers.joe.
he said ans i quote
cheers.joe.
