I did a ring and valve job this spring, and today I noticed oil around the front two head bolts on the passenger side, and some oil around the front two plugs. I wanted to check the torque on the heads and I'm sure it was 40 lbs and if it is the torque is fine. I tried to find on the home page the head torque specs and I can't find them. If this isn't the problem anyone got any suggestions as to why the oil. I checked the valve cover and it seems fine. I cleaned the oil off of the head bolts and started the car up. I swear I could see oil seeping out around the head bolt.
