well i replaced spark plugs, wires, cap and rotor and the fouling seemed to disappear. which is good, but the issue of low stumbling rpm persists.
i started checking for possible vacuum leaks. pcv etc. i pulled the outlet tube for the transmission modulator at the carb base and the rpms suddenly went up.?
i pulled the carb and replaced the base gasket it seemed to help but stumbling still persists. its been about 2 years since last rebuild.
any input,
thanks!
