Oil leak?
Greetings gents,
I have what may seem like a stupid question, but this is the first time I've ran into this and can't figure it out.
I'm getting oil filling in around two of my plugs and these two continue to foul out after about two weeks of regular driving.
Any help would be nice.
thanx...Ded N. Buried
Ded, you say oil leak, is the leak external or what cylinders are fouling the spark plugs. What brand plugs are you running??
Have you run a compression check?? NEED MORE INFO ON YOUR ENGINE?
Such as miles on the engine?? William
The leak does not appear to be external, not at that location anyway.
Its the number 2 & 5 plugs.
Autolite is what's in there now, but I have tried others to the same result. They just get all gunked up. I hit'm with a wire brush and they are as good as new.
Do not have a compression check.
This is just a crate engine I bought a few years ago at the autozone until I could get mine rebuilt. For the price its been a good one. I just would like to keep it going as long as I can. It's not burning any oil. and the leaks only equate to about one quart between changing. Not bad for $800.
Thanx for the reply
