Hello everyone. I'm in the process of ordering a replacement oil pump for a 61 Falcon. I'm not sure if it's the 144 or 170 (how do you tell them apart?). Regardless, Melling offering two pumps which they say work for both engines. Are there any brands other than Melling to consider? I haven't found any searching.
One of the pumps has a neck which is 5/16th of an inch longer than the other. There's an M-65 which is the shorter, and an M-65C which is the longer. How do I determine which to order?
Additionally, both pumps only come with one gasket. Does the pump need two (one for the engine block surface, and one for the pickup tube), or is one supposed to be a metal to metal contact?
