Oil pump gasket
Hi, I believe Ford did not use a gasket on the pump to block surface. Most gasket sets come with one and I use it. Good luck
Ford did not use one..I think that you are better off without one because the mounting ears do not get pried down because of the squishing of the gasket, a more stable mount..I worry about leakage so I use some gasket maker and bolt it down lightly then remove, removing any material by ports..One is needed at pickup.
