All Small Six Oil to turbo?
ActionYobbo
Where are you getting the oil for the turbo?
I read what I could find on setting up a turbo on a 200 but did not find where the oil feed is taken from. I assume the port for the oil pressure sender would be the spot
Yeh, just tee off the oil pressure outlet at the rear of the block. A small line is OK, as the turbo doesnt need much oil flow. I would use a flexible line that is heat resistant. Drain is important, it must go into the sump above the oil level and needs to be IMO no less than 13mm ID. You could go in through the fuel pump hole if your not using it. You must have a good crankcase breather arrangement so that the crankcase never has pressure, otherwise the turbo cant drain and oil will overflow into the compressor housing.
