Before replacing your radiator check the temperature of the top and bottom tank with an IR temp meter and stick a cheap dial thermometer in the radiator cap opening that can be bought at any grocery store.
You seem to have covered all the bases. It sounds like you rebuilt the engine. If so did you bore it out and how much?
Any new radiator will out perform any old radiator of the same capacity, but you might cover up some other problems that could came back to haunt you in a few months as the new radiator ages and loses some performance.
The cooling system must dissipate the heat the engine is making to produce the horsepower to meet demand; if not the temperature of the working fluid (coolant) will rise until the dissipation rate matches the production rate of heat, within practical limits. Simple thermodynamics. You can increase the dissipation rate by increasing the surface area of the heat exchanger (radiator) the coolant flow through the exchanger, the air flow through the exchanger, decreasing the temperature of the air through the exchanger, increasing the temperature of the coolant flowing through the exchanger and or increasing the coupling coefficient of the exchanger from coolant to air.
