Right. I have a 1962 Falcon with a 1967 200/6 with pacemaker headers and a DUI dizzy setup and a HW 5200 carb.
I've been futzing with my rebuilt Stovebolt HW 5200 since I bought it a few months ago, and I wrote a post the other day mentioning that I couldn't get the idle circuit to jet correctly. According to the manual, the idle mixture screw should sit at 1.5 turns out when everything is at its happiest.
Mine sits about 3.5-4 turns out with an idle jet of 80 - the largest available jet. i.e., I can't richen it any further. And I shouldn't even be close to that rich anyway. Anyway it's running very rich at idle and gets crappy mileage in the low speed circuit.
One suggestion is that I have a vacuum leak in the system someplace. I have only two vacuum lines: one from the intake to the C4 automatic tranny, and the other to the PCV valve on the rear of the valve cover.
Today I ran all new lines and fittings for all of that and I found that if I disconnect the PCV line and plug it at the manifold, the engine ran terrible until I .... can you guess? ... cranked down the idle mixture screw to 1.5-1.75 turns. Right where its supposed to be! Hot dang!
But, you know, geez, I'd like to have a properly working PCV setup. So I replaced the valve, the hose, and the manifold fitting. No change. With everything connected, and the mixture screw out 4 turns, I get 22hg on my vacuum meter. I get about the same with the PCV plugged off and mixture set at 1.75 turns.
So why is it that the mixture apparently is only happy when the PCV is disconnected? I think I have a good fit at the valve cover. When I lift out the PCV valve the engine idle drops and stumbles. The line seems not to be leaking.
I'm confused. I don't get it. I need some ice water.
